J Riemersma
#1 Posted : Sunday, February 3, 2013 8:49:29 AM(UTC)
J Riemersma
I replaced the idler pulley shaft lever assembly for the belt, and also replaced the belt. The dryer worked great for about 3 loads then it started shutting
off in mid cycle and not re-starting until it sits awhile. I see it could be the overload protector stopping the dryer, which it now does after only 5 minutes of use. Everything looks to be put together correctly. Any Ideas??
