BOTTOM INSIDE LIGHTS OF REFRIGERATOR DO NOT LIGHT UP. REPLACED BULBS, STILL DO NOT LIGHT UP. DO I HAVE TO REMOVE PART? WHAT DO I DO?:confused:
Groups: APP Team
Hi. With the refrigerator unplugged remove the lower light socket, plug the fridge in and use the multimeter to check if there is 120VAC across the socket contacts. If you are getting proper voltage - replace the socket kit Part number: 4387478
