Kahlo
#1 Posted : Thursday, January 31, 2013 6:45:06 AM(UTC)
Kahlo
The freezer is cold, but not the fridge. There is only a tiny bit of ice on the back of the freezer.
Simon / APP Team
#2 Posted : Thursday, January 31, 2013 12:05:47 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Is the evaporator fan runs?If it does proceed as follows:
To determine the problem you'll need to remove the evaporator cover (you call it the back of the freezer) and check if the evaporator coils are blocked with snow.
If they are you have to check the continuity of the defrost thermostat and defrost heater.
Part number: 67003426
Part number: 67002493
Here are the breakdown diagrams and 05-Evaporator Area & Rollers parts for Maytag MFF2557HEB - AppliancePartsPros.com
The defrost thermostat must be ice cold when checked.
If both are OK - then you need to replace the control board
Part number: 12784415
It's #5 on the diagram.
Post the results.
Simon.
