steve g
#1 Posted : Thursday, January 31, 2008 7:11:42 PM(UTC)
steve g
replaced thermostat in oven. will not shut off. any possibility of defective part?
#2 Posted : Friday, February 1, 2008 11:11:34 AM(UTC)
Hi Steve,
In order to provide the most accurate advise I need the complete model number of the oven.
steve g
#3 Posted : Saturday, February 2, 2008 9:17:56 AM(UTC)
steve g
kenmore model 362. 75296790 ser 7v128380p
#4 Posted : Saturday, February 2, 2008 11:50:35 AM(UTC)
Hi Steve,
If you replaced the oven thermostat with the brand new part
UserPostedImage
and the oven does not shut off, it could be the defective part or shorted wires to the oven igniter.
Check if the oven will go off with one of the wires disconnected from the oven thermostat.
If it would then you have to contact the place supplied the part for the warranty exchange.
Otherwise check the wires and the proper electrical connection at the power cord. The black wire should be connected to the hot line and the white wire should be connected to the neutral line.
- The part number for the oven thermostat is AP2623073
steve g
#5 Posted : Sunday, February 3, 2008 8:08:04 AM(UTC)
steve g
It shuts off when you rotate the knob to the off position, but does not shut off when it reaches set temp. Wiring is fine.
#6 Posted : Sunday, February 3, 2008 10:42:14 PM(UTC)
Hi Steve,
Most likely the oven thermostat is defective.
Who ever sold it has to exchange it under the warranty.
