need replacement instructions
Groups: APP Team
Hi. Use a flat screw driver to pry out the front edge of the grill #39 and pull it out.(Be careful not to brake it). Take out the screw and pull out the bottom#2. Remove the evaporator cover. Pull out the evaporator motor assembly with frame. Replace the motor and reinstall everything in the reverse order. Here are the breakdown diagrams and Cabinet parts for GE GBS18HBPBWW - AppliancePartsPros.comThe motor Part number: WR60X10300
Simon.
