blnp64
#1 Posted : Friday, January 25, 2013 9:55:38 AM(UTC)
blnp64
my turntable will turn if I turn it prior to starting the micro but only for a short time then stop. Why is my turntable not working
Simon / APP Team
#2 Posted : Friday, January 25, 2013 10:34:41 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to check two things:
First check if the slot in the middle of the support is intact
Part number: 5304440284
Then using the multimeter check if there is 120VAC to the turn table motor when the microwave is ON.
If the proper voltage is present - replace the motor
Part number: 5304440021
Here are the breakdown diagrams and Oven / Cabinet parts for Frigidaire FMV156DSB - AppliancePartsPros.com
Post the results.
Simon.
