wgeorgette64
#1 Posted : Wednesday, January 23, 2013 1:15:06 PM(UTC)
wgeorgette64
i have a LG dishwasherwith errorcode OE which is drain line clogged dis-connected hoses and drain line still having problems
Simon / APP Team
#2 Posted : Thursday, January 24, 2013 10:15:46 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to check if the drain pump is running. If it is and there is no drain - replace the pump.
If it's not running - check for 120VAc across the pump contacts and if the proper voltage present - replace the pump.
No voltage- check the wiring to the control board and voltage output from the board.
No voltage - replace the control board.
Here are the breakdown diagrams and parts for LG LDF6920ST - AppliancePartsPros.com
Post the results.
Simon.
dews40
#3 Posted : Friday, July 5, 2013 1:18:01 PM(UTC)
dews40
Simon,
What happens when it works, but won't shut off few several minutes after each time it drains???
Deb
