My oven showing F3 error code when turn oven on, did some research on your web site it recommend a bad Temp sensor. I bough new temp sensor and replace it and still have the same F3 error flashing on screen. What is next Please help. Here is the reading at room temp original Temp Sensor......1088 ohm new Temp Sensor......1095 ohm
Thank you Kalaya
