kowalcsl
#1 Posted : Sunday, January 20, 2013 12:18:52 PM(UTC)
kowalcsl
Received my Door Frame (SS) from AppliancePartsPro but I can not seem to disassemble the door to replace the cracked door frame (P/N: W10245708). I have removed a series of T-10 screws, but I am cautious to begin prying on the glass door. Can someone point me to door dis-assembly instructions for the Whirlpool Velos Microwave oven?
#2 Posted : Monday, January 21, 2013 12:42:56 PM(UTC)
Hello,
The instructions are attached to the post.
Here are the breakdown diagrams and Parts for Whirlpool GH7208XRS0 Microwave - AppliancePartsPros.com
File Attachment(s):
Removing the oven door components - part 1.doc (1,009kb) downloaded 35 time(s).
Removing the oven door components - part 2.doc (875kb) downloaded 28 time(s).
jimay
#3 Posted : Tuesday, July 16, 2013 11:39:14 AM(UTC)
jimay
I THINK that the model numbers ending with "1" are a tiny bit different.
There is an unused socket on the "user interface" board (W10115588) in steps 4 C&D. It's the one in the lower left of the pictures. There is no wire to plug into the socket.
The model number on my unit ends in "1" instead of "0", so it is a later model. I suspect this might be an engineering change in the later models?
This - is - why - you - use - your - cell - phone - to - take - pictures - as - you - take - things - apart...
So you don't have to go looking for a wire that isn't there...
