Groups ready for retrieval: Registered
Dishwasher stopped spraying water. It will fill with water but does not spray. The motor sounds okay.:confused: I tried many different washing combinations and even tried a dishwashing cleaning agent with super hot water. We have been washing dishes by hand for a month. :( I had a really bad experience with a dishwasher repair man once, and do not want to pay $$$ to fix it when I could buy a new one for a little more $. I would like to do it myself, but not sure want to do.
Groups: APP Team
Hi. Here are the breakdown diagram and Motor-Pump Mechanism parts for GE GLD4560N10SS - AppliancePartsPros.comYou need to check: -if the fine filter #451 and coarse filter #502 are clean. -if the ball is still inside the tube in the sump #505 and it's moving free up/down. Moving up/down the ball is switching cycles from wash to drain redirecting the water flow. Post the results. Simon.
