About Us
Appliance Parts
My Account
Order Status
Shop for Parts
Get Repair Help
Welcome Guest! You can
not
login or register.
Forum
Active Topics
Search
Help
OK
AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Water dispenser noise and low pressure
Email this topic
Watch this topic
Print this topic
» Normal
Threaded
Model:
MFI2568AES
Brand: Maytag
Age: 5 - 10 years
Previous Topic
Next Topic
bolero680
#1
Posted :
Sunday, January 13, 2013 11:58:35 AM(UTC)
[FONT=Arial","sans-serif]
My refrigerator is one of those that began making noise when dispensing water
[/FONT][FONT=Arial","sans-serif]
and when the ice maker is refilling. I changed the
[/FONT]
filter with no effect. Next I checked the supply line and there was some but very little pressure. I upgraded the line from 1/8" tap to cold water line to 1/4 braided steel to a valve on the cold water line. This time water came out of the line as a solid stream. Connected the new line and appears to have taken care of the noise when the ice maker kicks in. However, the noise is now louder when using the water dispenser with no change in water pressure except during the first 1 to 2 seconds (no noise) and then it turns to a trickle with noise. The noise/vibration comes from the filter assembly/back wall area. I read some of the entries on this subject and removed the water tank and flipped it a couple of times and saw air bubbles going up and down from each of the 5 tubes and at the same speed so there was no ice. Still I immersed the tank in hotwater for 10 minutes with same results. Only items I think I have left to test are the dual water valve and the head assembly attached to the water tank. Given the above, do you have any suggestions?
[/FONT]
No suggestions received opted to replace the dual water. No change. Are there any moving parts in the filter connector that could be the reason for the noise?
[/URL]
[URL="http://www.appliancepartspros.com/answers-for-whirlpool-water-tank-head-12956202-ap4014201-question-60118.html"]
User Profile
View All Posts by User
View Thanks
By Model Number
By Part Description
By Part Number
powered by
Guest
(2)
- Dishwasher Repair
- Dryer Repair
- Garbage Disposer Repair
- Heating, Ventilation, and Air Conditioning (HVAC)
- Microwave Repair
- Oven Repair (including Ranges and Cooktops)
- Refrigerator & Freezer Repair
- Trash Compactor Repair
- Washer Repair
- Blender Repair
- Appliance Parts
- Forum Announcements
- General Talk
Local Appliance Repair Companies
- Appliance Repair Companies - East of the Mississip
- Appliance Repair Companies - West of the Mississip
You
can
post new topics in this forum.
You
can
reply to topics in this forum.
You
can
delete your posts in this forum.
You
can
edit your posts in this forum.
You
cannot
create polls in this forum.
You
can
vote in polls in this forum.
Privacy Policy
Powered by YAF.NET
YAF.NET © 2003-2025, Yet Another Forum.NET
