Located model #, tgf334bcde. Is the igniter the cause? Where is it located?
Burners work, glow plugs work--oven does not light. Found model # tgf334bcde.
Most likely the problem is a bad oven igniter (#19 on the diagram). You have to remove the oven floor and the flame spreader to access the igniter. - The oven igniter Part number: AP2150412
That's what I thought. Thank you for your time. ~Ken
