Originally Posted by: Simon / APP Team  Hi. Check if you are getting 120VAC to the power board between Red/Blk and LtBlu? If you do then check the harness ribbon and replace the switch control board Part number: 241708306
You can return the power board for full refund. Post the results. Simon. thanks for your help. I checked the 120vac and the harness ribbon continuity. all ok. i noticed some substance on the harness ribbon connector and cleaned it. when i reassembled everything with the old board iit all worked. thanks again paul
Groups: APP Team
