drebeck
#1 Posted : Monday, January 7, 2013 10:47:00 AM(UTC)
drebeck
My dishwasher responds to the control panel. However, when I hit the start button, nothing happens except the timer runs down. The diswasher is not filling with water.
Simon / APP Team
#2 Posted : Monday, January 7, 2013 11:21:10 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check if the water is on, next open the door and remove the float dome in the front left corner and check if the float is down.
If it is, remove the kick panel and check if there is 120VAC to the water inlet valve and the flood switch.
If not - trace the wires to the control board.
Here are the breakdown diagrams and Body parts for GE GLD6700N20BB - AppliancePartsPros.com
Post the results.
Simon.
GE Quiet Power 3 middle arm problem (Dishwasher Repair)
by wun734 9/8/2014 7:42:44 PM(UTC)
ge quiet power 3 shuts off (Dishwasher Repair)
by calvinb 5/22/2013 11:23:50 AM(UTC)
GE Quiet Power 3 will not fill (Dishwasher Repair)
by ThePureOne 1/28/2012 10:02:36 AM(UTC)
GE Quiet Power 3 Will Not Drain (Dishwasher Repair)
by piranetus 3/27/2011 3:47:55 PM(UTC)
GE quiet power 3 will not reset (Dishwasher Repair)
by bjurasic 5/6/2010 7:59:30 AM(UTC)
GE Quiet Power 3 won't drain (Dishwasher Repair)
by shdwlkr 3/11/2010 12:25:46 PM(UTC)
GE Quiet Power 3 Turns on, but no water! (Dishwasher Repair)
by yorkbronson 12/23/2008 4:02:43 PM(UTC)
GE Quiet Power 3 Bad Bearing? (Dishwasher Repair)
by ccraymo 10/20/2008 4:34:13 PM(UTC)
