falsales
#1 Posted : Monday, January 7, 2013 7:08:47 AM(UTC)
falsales
Just installed a new clutchless 2 speed motor to replace the old 2 speed clutch motor. Now it works fine thru all the cycles until the final spin where it won't spin unless the tub is empty. Since it is a topload with magnet on door I get it spinning, empty, then throw clothes in one at a time, let it build up to speed then another piece of clothing and so on until it stops spinning at the end of the cycle. Also the 2nd rinse is shut off but the red light on control goes on and it does a second rinse. I blew into the pressure hose and heard the control knob click and nothing in hose. Could it be the control board or the transmission?? It agitates and spins well until final cycle when clothes are soaking wet and spin wont go on..Clothes are soaking wet but no water left in tub after draining.
