rusdkin
#1 Posted : Sunday, January 6, 2013 11:30:47 AM(UTC)
rusdkin
the agitator is not spinning at all,the water is draining ok, I checked the belt and pulley, the pulley is turning fine and the belt shows no fraying. Does this model require special tools to remove the agitator and fabric disp. assembly, or is this only able to be removed by a service person?
sidfink43
#2 Posted : Monday, January 7, 2013 4:56:17 PM(UTC)
sidfink43
See if there is a screw that holds the agitator on under the fabric softener cup. Unless the agitator is loose thought this could be a transmission problem.
Agitator problems (Washer Repair)
by pinkcuda 1/25/2014 12:51:15 PM(UTC)
Centennial Agitator Problems (Washer Repair)
by Dgrega 10/10/2011 7:52:43 AM(UTC)
by artsolisjr 12/1/2008 9:48:12 AM(UTC)
