The ice maker fill tube drips a small amount of water over time and eventually freezes up. This causes the unit to stop making ice. I have tried to defrost the frozen fill tube with a hand held steamer and the ice maker will work for a few cycles but the fill tube will freeze again. I have actually seen droplets of water run down the fill tube after the ice maker had finished dispensing water to the ice tray. I suspect the problem might be a faulty water valve. Please help! Thank you.
Please respond my question! Thank you.
Groups: APP Team
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Ice maker fill leaking when retrieving water
Rank: Guest
