teb02
#1 Posted : Friday, December 28, 2012 8:28:18 AM(UTC)
teb02
The dispenser will not switch from water to ice. The refrigerator temp (+) up also will not work. When the ice, water, or temp + buttons are pressed the power, filter replace, lock out and light on lights flash. I tried to do a key pad test, but since the + temp button does not work it will not go into service mode. The circuit diagram does not have a pin test for the touch pad. I am thinking that the touch pad is bad, but it could be the disp. control. What is you advice?
Thanks, Tommy
teb02
#2 Posted : Monday, December 31, 2012 6:25:15 AM(UTC)
teb02
Little help please?
Simon / APP Team
#3 Posted : Monday, December 31, 2012 10:27:22 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the problem is - bad touch control/overlay Part number: W10315984
Here are the breakdown diagrams and Dispenser Front parts for Whirlpool GI5SVAXVL00 - AppliancePartsPros.com
Post the results.
Simon.
teb02
#4 Posted : Monday, January 7, 2013 5:36:28 AM(UTC)
teb02
Hey Simon,
Installed the new touch pad on Saturday and it worked like a charm. Thanks for the help.
Tommy
Simon / APP Team
#5 Posted : Monday, January 7, 2013 1:30:46 PM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome, Tommy.
Simon.
