radwasher
#1 Posted : Thursday, December 27, 2012 1:20:12 PM(UTC)
radwasher
We have had an issue with the dishwaher, it stopped running and we are not certain of the problem.
Possibliy the fused link but I need to know how to test that componenent.
Dishwasher Fuse, Kenmore 675813...
Can anyone here supply me with the value of what to read on the existing fuse so that I can test it...?
Thanks,
rd
Simon / APP Team
#2 Posted : Thursday, December 27, 2012 3:57:26 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Here is the thermal fuse Part number: 675813
Part number: 675813
It's clipped on the side of the control board and you can check it by testing it for continuity. You will need a multimeter.
Remove the kick panel and find there a tech sheet with instructions.
Simon.
radwasher
#3 Posted : Thursday, December 27, 2012 5:26:47 PM(UTC)
radwasher
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Part number: 675813
Simon.
Thanks Simon,
I did locate the fuse and checked only for continuity, it is open... I did not know if that was all I needed to test for.
Good deal, I also did not know about the kick panel hiding a diagram. I cannot seem to pry the panel off. Try again after breakfast.
Thansk very much,
Rob
Simon / APP Team
#4 Posted : Thursday, December 27, 2012 5:37:43 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Do not pry anything off! There are screws holding it.
When replacing the fuse use the new wires in the kit.
Simon.
radwasher
#5 Posted : Friday, December 28, 2012 4:24:52 AM(UTC)
radwasher
Hi.
Simon.
Yeah, that was a poor choice of words, I will check for the screws on the panel, 10-4 on the wires...
We still have snow clean up to do so I'll check this out later...
Oh, I have a jumper wire to test / verify that the fuse is the culprit. There should be no danger in checking that, correct..? Running the washer just for a few seconds with the jumper instead of the fuse...?
Thanks again,
Rob
Simon / APP Team
#6 Posted : Friday, December 28, 2012 10:13:39 AM(UTC)
Simon / APP Team
Groups: APP Team
Yes, you can do that.
Simon.
