acosto04
#1 Posted : Monday, December 24, 2012 1:19:34 PM(UTC)
acosto04
Yesterday, I took my dryer apart, cleaned out the lint and replaced the white and gray slides due to a grinding noise. I put it back together started it and it sounded great. My wife put a load in and started the dryer, it ran for about 10 minutes and stopped, it sat for about 10 minutes and restarted on its own. I took the dryer apart again, checking the motor for any additional lint. Put the dryer back together restarted it and it stopped again mid cycle and started back up on its own after sitting for a few minutes. I pulled the dryer out from the wall disconnected the vent hose and restarted the dryer and the same thing occured, it ran for a while, shut down, sat for a few minutes and restarted on its own. Thoughts?? Thank you in advance for your time and consideration of this matter and Merry Christmas,
Simon / APP Team
#2 Posted : Monday, December 24, 2012 4:41:53 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to determine if the problem is the hi - limit switch, motor or the control board.
Remove the top (3 screws at the back slide and lift up), Locate the main control board Part number: WE4M488
When the dryer fails and stops use the multimeter to check if there is 120VAC at the 3 wire plug OR(3) and WH(2). If the voltage is present - the hi-limit is open and you should check the entire air flow system for restrictions.
If not - move to the 4 wire plug and check for 120VAC from PURP(3) to Brown/Yellow(2).
If the voltage present - most likely it's the bad motor.
If no voltage - bad control board.
The motor Part number: WE17M42
volleeg
#3 Posted : Tuesday, August 30, 2016 9:28:28 AM(UTC)
volleeg
My dryer was doing the same thing, stopping randomly, starting again, pressing start button and display would show "drying" but the dryer never started. As luck would have it my wife's solution was to give the door a "slam" OK, a few slams and the dryer would start. This got old really fast, and her method of starting the stubborn dryer got less and less effective.
Needless to say the problem was at best intermittent. I thought it was the door switch, but proved it was fine by holding the switch "in" while I started the dryer, both when it worked and when it only said it was "drying"..well, that would have been too easy anyway...
So off comes the cover, power board & control panel in view, both suspect at this point, find the yellow paper, check the wiring schematic, kinda Greek and all.
So in my poking around in there I bump the wires that go into the 4-pin Molex connector (mid power board, all the way to the right) and lo and behold the dryer starts! Well look what we've found, a loose wire connection to the board! Kinda explains the randomness of the problem and how the vibration from my wife's solution worked, wiggle the wire(s) and it would "start", also wiggle the wire(s) and it would stop.
What to do? GE doesn't sell wiring parts or a harness, plus I need the special tool to remove and re-crimp new female pins from inside the molded plastic "plug". I tried splaying the ends of the male pins soldered to the board with an o-ring pick, seemed to work, closed the dryer up ran great for a while, then more of the same, wash-rinse repeat...
I checked the board-mounted pins for cracked solder, ohmed them out, all was fine, simply some worn out female connectors in the Molex plug. Surely a low $ item if you can get them..
For the minute, I've left the cover off and will jostle the wires to get her going...Just an observation, but the plugs are considered "vertical" plugs with the wire leaving at a 90 degree angle, really could have used an inch or two more wire so as not to make the bend so sharp thus stressing the pins less.
At this point a replacement harness (used or new) would be ideal, but I guess I'll have to bite the bullet and get the right tools for the job. Any suggestions would be greatly appreciated...sorry this was so long, but I think it will help someone. :)
DJFW
#4 Posted : Friday, December 8, 2017 10:38:57 AM(UTC)
DJFW
@volleeg
Did you find a solution to the molex plug problem?
