nelsen2605
#1 Posted : 15 years ago
nelsen2605
Microwave stopped heating. Interior light comes on, fan comes on, carousel rotates, but no heat. Could you provide steps for determining what's wrong?
Thanks.
glen65
#2 Posted : 15 years ago
glen65
First keep in mind that the electricity in a MW can
reach thousands of volts even when turned off.
Something I would want to see is if there is 120 volts AC
reaching the primary of the transformer while running.
If not then you could be looking at anything from a
bad wire connection to the circuit board itself that has
to send primary voltage to the transformer or any other
component in between. If the voltage at the primary winding
does exist then there most likely is a high voltage component
itself such as the transformer itself or one of the other high
voltage components.
nelsen2605
#3 Posted : 15 years ago
nelsen2605
OK, thanks. I'll check out the high voltage at the transformer over the weekend and get back to you. I appreciate the help.
glen65
#4 Posted : 15 years ago
glen65
:eek: NO!
Keep away from the high voltage.
I was clearly referring to the primary voltage.
If you don't know how to check it then call someone who does.
nelsen2605
#5 Posted : 15 years ago
nelsen2605
Got it. Sorry for using the wrong terminology. I have someone to help who knows the difference.
nelsen2605
#6 Posted : 15 years ago
nelsen2605
Glen,
I measured 0v at the primary of the transformer when the microwave was running. However, when I disconnected the wires to the primary and measured the voltage at the wire ends with the microwave running, it was 120v. It would appear that the transformer or something on the other side of the primary is pulling the voltage to 0v.
One other note .... occassionally, when running the microwave, there is a lower sounding hum than normal and the voltage measures 23v at the primary. But most of the time, it is 0v.
How would I check whether the transformer, high voltage capacitor, diode or magnetron is the problem?
SEDNARB
#7 Posted : 15 years ago
SEDNARB
Microwave Starts For About 10 Seconds Then There Is A Click After Which There Is A Humming Sound And No Heat. Can You Diagnose
GE Microwave won't heat (Microwave Repair)
by Jim T 16 years ago
by Bburgi 17 years ago
