I had a clicking sound coming from this range a while back. I did some research that led me to believe it was the infinite switch. I changed this and, I suppose by some coincidence, the clicking stopped for a few weeks. It is now started again to the point that I would like to get to real source. This only happens when the cook top (electric-down draft-smooth top) is off. I have read several posts here and elsewhere but cannot be confident of a fix. Any recommendations? Thanks Howard
Were you able to fix this issue?
I have the same problem
