Kewpy
#1 Posted : Monday, September 28, 2009 10:21:02 AM(UTC)
Kewpy
Evaporator was totally iced up, Fan is ok.
Following instructions I found, I jumpered J11 (Line) and J9 (Defrost Heater), and plugged unit in. The heater did not glow or get warm. (I assume it should happen right away because jumpered)
I removed heater, and tested for continuity with Digital Multimeter, but it seems open. Also, glass is very dark. I put heater back in and with jumper still on J11 to J9 I checked for voltage at each end of heater and ground, but got zero volts.
Back on motherboard, I removed jumper from J11-J9 and checked for voltage between J11 (Line) and chassis, but got zero as well.
It seems that heater went bad and possibly took the motherboard out as well?
I should add that a few days before we noticed the refrig. getting warm, we heard a "groaning" sound from the area of the Ice maker/evaporator fan, but it went away after a day. When the cooling problem surfaced a few days later, the first thing I looked at was the evaporator fan, but it seems fine and noise has not returned. Not sure it was related, but wanted to mention that.
Thank you.
Kewpy
#2 Posted : Wednesday, September 30, 2009 5:50:01 AM(UTC)
Kewpy
No ideas from anyone?
Plenty of views of my post, but I guess no one has experience diagnosing the motherboard.
