My icemaker is not working. It may be coincidence but the filter light turned red around the same time. I changed the filter, but the icemaker still don't work. I don't know which component is failing how do I diagnose the different components?
Originally Posted by: diamonddave ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My icemaker is not working. It may be coincidence but the filter light turned red around the same time. I changed the filter, but the icemaker still don't work. I don't know which component is failing how do I diagnose the different components? There is no water in coming into my icemaker. I changed the filter and Dual water valve. What is next?
