scott schultz
#1 Posted : Wednesday, January 30, 2008 1:21:26 PM(UTC)
scott schultz
:eek: When we push the water button in the refrigerator no water comes out. Pump makes a noise but no water. There appears to be water at the filter.
#2 Posted : Thursday, January 31, 2008 11:24:12 AM(UTC)
How old is the filter?
If it's more then a year old - most likely the problem is a clog in the filter.
- The part number for the water filter is AP4260337
scott schultz
#3 Posted : Friday, February 1, 2008 9:11:14 AM(UTC)
scott schultz
thanks for your quick response Gene, had filter removed and still no water coming. Is that normal?? Will try replacing the filter. Thanks.
#4 Posted : Friday, February 1, 2008 11:07:17 AM(UTC)
If you have the filter removed, you have to use a filter bypass (special part). Otherwise there would not be any water flow at all.
scott schultz
#5 Posted : Friday, February 1, 2008 12:33:50 PM(UTC)
scott schultz
Thanks again I will try the filter;unk. age of filter ,we just moved in recently. Thanks again.
#6 Posted : Friday, February 1, 2008 2:24:41 PM(UTC)
Keep me updated, please.
martucha
#7 Posted : Friday, February 8, 2008 5:52:13 AM(UTC)
martucha
good morning. I need your help please I just change the igniter because the old one did not glow at all the new one glows but the burner do not get flames, but its passing gas if I put a match get the flame. what it can be please i need your help please.
thanks. martha:confused:
#8 Posted : Friday, February 8, 2008 8:13:25 AM(UTC)
You probably installed the new igniter in the wrong position.
I need the complete model number of the range and the picture of the burner with the new igniter (if possible).
