Seems that there are no available repair parts for my Dacor double oven ECP52275. I need a new touch panel part #62208B. The oven works fine except for one button on this panel which does not allow adjustment for temperatures less than 350 degrees. A new oven is $5000! Any info about touch panel repair or a line a a new/rebuilt panel would be greatly appreciated. Marc gitman97@gmail.com
I cannot find any info on either of the model numbers you give.
Perhaps try the following if it is applicable.
Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try. |
THIS FORUM IS DEAD!!!!!!! |
