City Tech
#1 Posted : Friday, December 14, 2012 5:50:19 AM(UTC)
City Tech
You have been a member since:: 12/14/2012(UTC)
I'm hoping someone can give me a way to correct this problem.
The ice maker does not make ice while the water in the door does flow fine. We have lost power (didn't make ice before losing power) a few times with storms so I know it is not because the line is frozen.
I believe it might be the light emmiter. I can't make the light (for the ice maker) go on with the door open - even though I press the flappers for both the freezer light as well as the ice maker.
How can I fix this issue?
Thanx much!
Simon / APP Team
#2 Posted : Friday, December 14, 2012 4:28:49 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely you need to replace the emitter and receiver boards.
Use the attached link for the diagnostics.
If you will provide the correct model number, I'll get you the part number.
Simon.
File Attachment(s):
