Don Cohee
#1 Posted : Wednesday, January 30, 2008 10:20:30 AM(UTC)
Don Cohee
Just purchased an igniter that will not glow at all. This is a self cleaning oven. Can the igniter connection be acccessed from the inside by removing the bottom burner pan, gas tube and heat shield. Or do I need to remove the rear panels on the back of the range to get access to the stove. The diagrams available do not show where the igniter is plugged into the power source. Any suggestion would be greatly appreciated to make the job easier. Thanks.
Confused about replacing oven igniter Frigidaire (Oven Repair (including Ranges and Cooktops))
by artemis 12/4/2017 9:24:14 AM(UTC)
