ZDaniel
#1 Posted : Thursday, December 13, 2012 2:50:10 PM(UTC)
ZDaniel
Far as I know I have checked everything that I know how to....
Freezer side seems to be ok, Fan in the back is working, I took the inside back panel off (Ref Side) and there is no ice buildup in the coils.
There is NO airflow from freezer to Refer as this is an independent system with cooling system for each side....
At first no matter what you set the temp at it would not change inside and after 5 seconds showed the actual temp of 50..... Last night I noticed the Power cool was on, I turned it off and reset to 34 deg, now it says it is 34 degrees in the refer side but it is not....it is just as it was, probably 50 degrees....
any advice?
I have tried to find a SERVICE Manual and all there is available is the owners manual.....
Daniel
ZDaniel
#2 Posted : Thursday, December 13, 2012 5:59:17 PM(UTC)
ZDaniel
The whole thing just took a turn for the worse, now it is defrosting both refer and freezer are warming up.....:mad:
