I am still having issues with my dishwasher and cannot get the clean light to stop blinking. I have replaced the Thermistor and the water inlet valve. I have also checked the heating element and am getting about 10 OHM on a multimeter. After replacing water inlet valve and thermistor, tried again and it filled and ran fine for about 20 minutes. I figured it is not the heating element or the thermistor as it ran longer than 8 minutes when the thermistor is suppose to detect that the temp has raised at least 2 degrees. Please help guide me to the next steps to check and details on what readings, compontents or wires I should check with the multimeter.
