My dishwasher stopped spraying the dishes. The water comes up through the bottom sprayer but its like it does not have enough pressure in order to spin that bottom sprayer. The water does not come up through the top sprayer either.
Groups: APP Team
Hi. First check if the water level comes up to the heater, then check the wash arm jets for restrictions (clogs), then check the pump filter Part number: 8519553
The water level is not up to the heater.What does that mean?
Groups: APP Team
Hi.
The screen inside the water inlet valve may be clogged.
Still check everything ells.
Simon.
I guess I dont know where the inlet valve is? Could it be the pump motor? I think I have checked that valve and its not clogged.
Groups: APP Team
Hi. Here is the water valve Part number: 8283345
It's located underneath of the dishwasher on the left. But first check the pump filter. Simon.
