junkman48
#1 Posted : Sunday, December 2, 2012 6:37:43 PM(UTC)
junkman48
dishwasher won"t turn on.
Cycle time and cycle selection lights blink.
Press cancel and time goes to 2 min but washer doesn't come on.
press a few more times and washer came on and ran two minutes to completion
then pressed normal wash and start. washer worked from 78 to 50 minutes then stopped.
pressed start -no response
pressed cancel -lights started blinking again -press again and lights go out
when press different cycles propper times for cycles apear but just blink and washer won't come on
I suspect control pammel bad, this is the first problem i have had with the unit. We have run unit every other day for over ten years . if you concur with bad control pannel would you replace it or buy a new dishwasher
#2 Posted : Monday, December 3, 2012 4:13:23 PM(UTC)
Most likely the problem is a bad control panel and I'm not sure if it's worth to fix it. The part is very expensive and the dishwasher is ten years old. It maybe better to buy a new one. In that case I would recommend Bosch.
Frigidaire Professional Dishwasher panel lights blinking (Dishwasher Repair)
by MikeCG 5/7/2012 5:05:53 PM(UTC)
