:confused: Went to use my microwave Saturday - opened the door after item was heated up and as I pulled the door open. Now I can't keep the door shut, the latch is not attaching to the lock and the light is permanently on. In order to heat things, you have to stand and hold the door shut. PLEASE Help?
Originally Posted by: bjohn123  :confused: Went to use my microwave Saturday - opened the door after item was heated up and as I pulled the door open. Now I can't keep the door shut, the latch is not attaching to the lock and the light is permanently on. In order to heat things, you have to stand and hold the door shut. PLEASE Help? Went to use my microwave Saturday - opened the door after item was heated up and as I pulled the door open. Now I can't keep the door shut, the latch is not attaching to the lock and the light is permanently on. In order to heat things, you have to stand and hold the door shut. PLEASE Help? Read more: http://forum.appliancepartspros...epair.html#ixzz34oqobg4Y http://forum.appliancepartspros.com
