dideyjohn
#1 Posted : Tuesday, November 27, 2012 6:06:54 PM(UTC)
dideyjohn
My washer starts up and goes through the wash cycle and then stops and within a few minutes of stopping I checked the three main valves resistance o see if any of them have open loop, nothing. Is it the man circuit board? Don't want to order it f I do not have to. We have plenty of water pressure - 50 pisg coming into house
sidfink43
#2 Posted : Thursday, November 29, 2012 4:40:57 PM(UTC)
sidfink43
This model has two control units, a main control unit and a speed/motor control unit.
Look inside the lower service panel for tech notes that will tell you how to do some testing on each one. At the end of the day however you may just have to replace each one to see which one is the problem. If you buy from this site you can return the part you do not need.
Also, the door lock mechanism can be a problem, so check it out also.
Washer stops mid cycle (Washer Repair)
by NevadaBill 7/3/2017 7:54:11 AM(UTC)
washer stops mid cycle (Washer Repair)
by postal13 4/18/2016 4:38:15 PM(UTC)
GE washer stops mid cycle (Washer Repair)
by APPLIANCEDUDE1972 3/4/2015 6:32:45 AM(UTC)
Dishwasher stops mid cycle (Dishwasher Repair)
by vpchianese 11/15/2013 2:32:24 PM(UTC)
Maytag washer stops mid cycle (Washer Repair)
by paubert03 12/2/2012 3:33:21 PM(UTC)
by tedwards353 2/20/2012 10:21:16 AM(UTC)
by maryprice4 10/17/2011 6:29:09 PM(UTC)
by ncdunn 3/31/2011 6:55:03 PM(UTC)
by krislinda 11/9/2010 12:52:34 PM(UTC)
Whirlpool Washer Stops Mid Cycle (Washer Repair)
by cfphillips 9/3/2010 11:01:15 AM(UTC)
by Dave W. 6/7/2010 10:59:53 AM(UTC)
Maytag SE 1000 washer stops mid cycle or won't start wash cycle (Washer Repair)
by katyat 9/10/2009 1:23:57 PM(UTC)
by CLK 7/19/2009 11:03:25 PM(UTC)
Frigidaire diswasher stops mid cycle (Dishwasher Repair)
by bhacker 7/17/2009 3:58:44 AM(UTC)
Whirlpool washer stops mid cycle (Washer Repair)
by kgundi 6/5/2009 7:39:39 AM(UTC)
