mlfort57
#1 Posted : Tuesday, November 27, 2012 7:49:41 AM(UTC)
mlfort57
I replaced the bake element in my Kenmore Range, hooked the element back up and still nothing. What's next?
Simon / APP Team
#2 Posted : Tuesday, November 27, 2012 4:57:36 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Pull out the range, take the back off, take one wire off the bake element (make sure it's not touching any metal surface).
Turn the oven Bake on and check out each bake element's wire to the ground for 120VAC.
Trace up the one without the voltage. Most likely it will lead you to the control board.
Now the bad news - the control is no longer available.
You can try to find somebody to rebuild the old one.
Post the results.
Simon.
