enzy216
#1 Posted : 12 years ago
enzy216
Hello Everyone
I have Maytag Gemini Double oven and I can't seem to get the thing to stop beeping randomly. The top oven works the bottom oven will not stay on and the broiler works. Whenever we go to heat up the oven it will continue to beep randomly. Now its getting to the point where it will beep for no reason (really annoying) I have read numerous people saying it is the control board anyone have any thoughts on this?
Sorry I can't provide a model number but I think I have found the prints to the control board with the part no. 8119p107-60
Anyone that can help me out that would be great
EnzY
#2 Posted : 12 years ago
Hi EnzY,
Did it show any error code?
The part number you posted is not a valid Maytag part number. The model number can be found on a metal tag located on the back of the control panel. Reach behind the top left corner of the control panel and rotate the tag up to view the data.
enzy216
#3 Posted : 12 years ago
enzy216
Hello Gene and Thank You for the reply. The stove is showing no errors just the clock which works fine. I pulled the oven out and I do not see any model numbers. The only thing I know is that it is a Maytag Gemini. We are currently looking for the manual that it came with so we can possibly find the model number. Hopefully by tomorrow I can provide that for you. Thanks for all your help and concern
Enzy
enzy216
#4 Posted : 12 years ago
enzy216
Hello Gene I now have found a part number and I am ready to fix this piece of crap! Now my food is not getting up to temperature so I do not know what is up with this thing. Hopefully you can help me out.
Here is the model number:
Maytag Double Oven Gas Range
Model#MGR6875
#5 Posted : 12 years ago
Hi EnzY,
This model number is incomplete. That makes impossible to find the correct part number for the control board. There are at least five different controls used. Try to get all numbers from the original part.
