dryer makes a noise like it is unbalanced. the belt is fine. have tried to level it, and that helps for a couple of minutes. what can i do?:mad:
It is difficult to diagnose a noise problem in a Forum like this because the primary way we do this is to listen and determine the type of noise and the location. On these models a failure of the rear bearing is frequently the problem, so I would see if you can determine if the noise is near the rear and if so, install this kit. Part number: AP2619300
While you have the dryer diassembled you might also replace the belt and the idler pulley parts, and then you should be good for a long time. Be sure the clean out the lint in the dryer, especially in the blower housing and vent to the outside.
