Hello, My dryer will not start. We turn the timer and you can hear it running and push the start button and the dryer buzzes but will not turn on. What could be the cause of this issue? Model: AL84200 Serial Number: ME3402879 Type: 122-00 Thank you for any help you can provide.
Groups: APP Team
Hi.
The model number you provided doesn't come up. Please check and re post.
Simon.
I have attached a copy of the sticker with the model and serial number jackiebremner attached the following image(s):
Groups: APP Team
Hi.
Looks like you are in Canada. Unfortunately I can't do any research because of absence of the info. If this is an electric dryer you should check if the thermal fuse is open. Also check the door switch.
Simon.
