Welcome Guest! To enable all features please Login or Registers.
Don Brackett
#1 Posted : Tuesday, January 29, 2008 9:06:06 AM(UTC)
Don Brackett
Ice cutter wire- replaced upper set (broken wire). ice still lays on upper wire
not cutting. what current reading should I get at cutter plug- Does transformer control heating? what else could cause cutter not to cut?
donandmonika@bellsouth.net
kooler
#2 Posted : Friday, February 1, 2008 10:45:34 AM(UTC)
kooler
You should have approximately 5 ohms resistance across the cutter grid wire circuit and 8.5 volts coming from the transformer to heat up the cubelet grid....
