How do I get to the screws/bolts to tighten the bottom of the handle on the refridgerator side of this double-door unit? Do I need to take the entire door apart or is there a simpler solution?
Sorry but I cannot find any info on the given model number, please check it. I tried here and the Frigidaire site
If the handle just sits on the front of the door then odds are it is held on by clips. Lift up on the handle being careful not to scratch the door. It should move up a bit and then you can remove the handle. You can then tighten the clip to the door if it is loose. Or the bolt on the handle which fits into the clip. |
THIS FORUM IS DEAD!!!!!!! |
I will try your suggestion! Thanks!
Sue
