MarkMinnc
#1 Posted : Tuesday, November 13, 2012 6:28:57 AM(UTC)
MarkMinnc
I have a Whirlpool Silent Partner dishwasher that came with a new home purchased just less than a year ago. It has been working normally until two nights ago. I started the dishwasher just before going to bed on a normal wash cycle. The unit was still washing the next morning. I stopped it with the cancel button and the dishes were still wet.
I tried it again and it fills with water for a few moments with the soak and wash leds on. Then starts washing with the wash led only on. After 30S-1M it repeats this sequence. And, continues to repeat the same process.
I have turned the main breaker off to try and reset it. I have tried all of the cycles and the only one which works as it should is the Rinse. The other cycles never finish.
ApplianceJunk
#2 Posted : Tuesday, November 13, 2012 7:15:04 AM(UTC)
ApplianceJunk
What is the model number?
MarkMinnc
#3 Posted : Tuesday, November 13, 2012 7:19:33 AM(UTC)
MarkMinnc
I have a Silent Partner III.
thanks,
ApplianceJunk
#4 Posted : Tuesday, November 13, 2012 7:21:21 AM(UTC)
ApplianceJunk
thanks,
That is not the model number. The model number can be found on the model/serial number tag that is on the dishwasher.
MarkMinnc
#5 Posted : Tuesday, November 13, 2012 7:32:29 AM(UTC)
MarkMinnc
HI,
OK, I will find and report that this evening, (am at work right now).
thank you,
