I've check the Fuse from the front panel and ohm meter reading that it is still good. But nevertheless no power to the oven.
Potato catch on fire wrapped in a paper towel. Was no physical damage just smoke and soot inside the unit. Is there a diagram to working on these units and troubleshooting guide?
Thanks in advance!
JSSnMO
can you double check that model number ?
Model number JVM1650WB008 straight from the Registration card.
That model number looks better: Besides the fuse, there's (4) TCO's (Thermal Cut Outs).
Thank you.
I am sure that will be of great value to me.
Have a good one.
JSSnMO had posted that he accidentally burn a potato in his microwave and got a reply stating that he needed to replace the thermal cut offs. Well the same thing happened to me. alot of smoke and soot and the thing is dead now. I would graetly appreciate some advice and if possible a diagram or schematic for troubleshooting.
Thanks much...........
