Hi, I have a roper dryer that I moved out of a basement that I'm giving to someone. Moving it was a lot of trouble and to fit it, I had to take the top off but when I did that, the start button wires came off. I don't remember the order and I can't figure it out from the diagram. One is black and the other is white/red. Any help is greatly appreciated.
Thanks in advance.
Sorry cannot find any info on this unit, probably too new.
Did find info on a RED4440SQ0 but it uses a Push To Start Relay not a switch. Also none of the wire colors seem to match yours.
If this is a switch with just 2 connectors it should not make a difference where the wires go but I cannot guarantee this. |
THIS FORUM IS DEAD!!!!!!! |
