I have a Maytag MDB7600AWQ dishwasher that has no power to the front panal. I changed the control board but still no power. Is there something else that could cause this problem.
Here are your parts, includes a wiring diagram. Parts for Maytag MDB7600AWQ Dishwasher - AppliancePartsPros.comHave you checked that the wire nuts which attach the unit to the house wiring are OK. Just looking at them is not good enough, you have to remove them and reinstall them. Make sure that the power is off when doing this. If they look OK then you need to check that there is actually power at the wire nuts with a meter. If OK then you have to check the door switches. |
THIS FORUM IS DEAD!!!!!!! |
