Groups: APP Team
I installed a new control panel and got nothing. I tried testing the transformer. I disconnected the power. I tested the 2 red with the wires off and it read .044. I tested the 2 blue and it was all over the place. Where to now. Control Board?
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Simon,
Model number is GBD307PRY01.
Serial number is XT5001087.
I am having the same problem as the above with my Whirlpool in-wall double oven. Lights work. Buttons beep. Digital time doesn’t display. If you push start you get one short beep, one long beep and then three short beeps. I have not run a cleaning cycle in a long time. Any thoughts? Are the transformer or control panel parts still available?
Thanks!!!
Rank: Guest
Simon,
Thanks!!!
Rank: Guest
So my oven works intermittently. At times the control display stops displaying information and the oven does not turn on. This seems to happen after using the oven to bake. Sometimes it takes an hour or more for the display to come back on. What are the probable causes and how to I troubleshoot to isolate this problem
