jredwe
#1 Posted : Thursday, November 8, 2012 8:43:34 AM(UTC)
jredwe
my dryer quit getting hot so i thought the heating element went out i decided to use the air fluff cycle i put the timer at 20 minutes and the dryer never shut off until i opened the door so now im thinking it the timer:confused:
#2 Posted : Thursday, November 8, 2012 1:31:23 PM(UTC)
Parts for Whirlpool WED5300SQ0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Did the timer advance but hang up just before off.
If yes then it is probably a blown heater.
If you look at the timing diagram you will see that the End Of Cycle gets power through Timer Switch 0 TM/OR contacts which gets it's power through the heating coil to drive the timer that last little bit to off.
File Attachment(s):
WED5300.pdf (232kb) downloaded 1 time(s).
