my gas dryer heats for 2-3 min of of run time then goes cold can see igniter lighting up then off this continues but no heat checked safte thermo and exit thermo both test good checked both both thermisters both read 7 ohms , any thoughts
Groups: Expert
Replace the split coils on the gas valve. That will fix the problem. Part# 279834
