My six burner Thermador gas cooktop PCS366 is having the following problems.
when I use either of the XLO (left hand burners) all the burners will continue to spark after the XLO burner lights.
In addition I have one burner (front middle) that will not spark when it is turned on but gas will flow anyway (I can light it with a match) and this burner will spark when the XLO burner is turned on, and if I turn on one of the XLO burners when the gas is flowing to this burner it will light.
I hope the explanation of the problem is clear Thank you for any advice and help
