Have traced that power is getting to the control board in the door of Maytag refrigerator, but none of the buttons or light works. Ice maker works. How can i be sure the problem is the control board or not? How can i get proper info to do a continuity check on the board and possibly find exactly where the problem is (service manual)
Groups: Expert
If you have 120 VAC between the WH wire and VT wire replace the board part "67006743
thank you very much rickgburton. Do have 120v, will replace that part.
