Hello!
i know this stove has been in existence for along time however it has been perfect and treated us the same way. One day i cleaned the portion where the clock is and accidentally pressed 3 buttons at the same time and now the clock will not turn on. Also, nothing else works. No burners and no stove is available for use! When i turn one of the burners on, the clock starts flashing and i am able to set a temperature heat for the stove, but it never reaches the temp i set.. Once i close the burner (and it doesnt matter which one) the clock turns itself off and everything stops working again.
HELP!
